Hi there, I’ve got a functioning LibreNMS install I’m trying to integrate with AD. It’s mostly working, in that my users can log in, but level setting via groups isn’t working. It LOOKS like Libre isn’t seeing the groups at all for some reason. In my config I have:
$config[‘auth_ad_global_read’] = 1;
$config[‘auth_ad_require_groupmembership’] = false;
$config[‘auth_ad_groups’][‘Role-L3.User’][‘level’] = 10;
And all my users are authing as level 5 even if they are in the group “'Role-L3.User”
I have confirmed that the user is in the group using:
gpresult -R
on a windows box. Output is
The user is a part of the following security groups
Domain Users
Everyone
BUILTIN\Users
NT AUTHORITY\INTERACTIVE
CONSOLE LOGON
NT AUTHORITY\Authenticated Users
This Organization
LOCAL
Role-L1.User
Role-L3.User
using the auth test script I get:
[email protected]:/opt/librenms# scripts/auth_test.php -u username -d
SQL[SET NAMES ‘utf8’]
SQL[SET CHARACTER SET ‘utf8’]
SQL[SET COLLATION_CONNECTION = ‘utf8_unicode_ci’]
SQL[SELECT config_name
,config_value
FROM config
SQL[SELECT * FROM graph_types]
SQL[SELECT DISTINCT(os
) FROM devices
SQL[DELETE FROM session
WHERE session_expiry
< ‘1518400399’]
Authentication Method: active_directory
AD bind success
Password:
Authenticate user username:
AUTH SUCCESS
User (1257):
user_id => 1257
username => username
realname => Real Name
email =>
descr =>
level => 5
can_modify_passwd => 0
Groups:
Where I have swapped my username for “username” and my real name is displayed. But it looks like It finds no groups that I am a member of?
Any suggestions?
Output of validate.php
[email protected]:/opt/librenms# ./validate.php
PHP Fatal error: Uncaught Error: Call to undefined function mergedb() in /opt/librenms/validate.php:138
Stack trace:
#0 {main}
thrown in /opt/librenms/validate.php on line 138
Component | Version |
LibreNMS | 1.36-63-g16424ef |
DB Schema | 235 |
PHP | 7.0.25-0ubuntu0.16.04.1 |
MySQL | 10.0.33-MariaDB-0ubuntu0.16.04.1 |
RRDTool | 1.5.5 |
SNMP | NET-SNMP 5.7.3 |
