As far as I can tell the alert should not be triggered as the voltage is higher than the low alarm and less than the high alarm…?
Obviously i have something wrong.
As you have got high/low limits in place you should compare the current one against that (FYI you’re checking the limit_low_warn value rather than the value from your device at preset).
In the drop down box for the field to check select customoids.customoid_current then select less or equal and in the value box enter `customoid_limit_low_warn` - The backpacks are important, they aren’t single quotes, they are explicitly backpacks.
