I’m using the current version of librenms on Debian 9 with Percona 8.
I noticed issues trying to use/create dashboards, after a bit of digging, I saw that in the users_widgets table contains a columns named ‘row’. row is a reserved keyword, and shouldn’t / can’t be used:
https://dev.mysql.com/doc/refman/5.7/en/keywords.html#keywords-5-7-detailed-R
This goes back to at least 5.5, so I’m not sure how it worked before (or works for anyone?)
mysql> describe users_widgets;
| Field | Type | Null | Key | Default | Extra |
| user_widget_id | int(10) unsigned | NO | PRI | NULL | auto_increment |
| user_id | int(10) unsigned | NO | MUL | NULL | |
| widget_id | int(10) unsigned | NO | | NULL | |
| col | tinyint(4) | NO | | NULL | |
| row | tinyint(4) | NO | | NULL | |
| size_x | tinyint(4) | NO | | NULL | |
| size_y | tinyint(4) | NO | | NULL | |
| title | varchar(255) | NO | | NULL | |
| refresh | tinyint(4) | NO | | 60 | |
| settings | text | NO | | NULL | |
| dashboard_id | int(10) unsigned | NO | | NULL | |
11 rows in set (0.00 sec)
mysql>; SELECT row from users_widgets;
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'from users_widgets' at line 1
