Hi All,
I have seen issues with LDAP on some of my instances through couple months where ldap test with ./auth_test.php passes but when try to login via gui , it does not work. Anyone in the same boat ?
- The output of
./validate.php
[[email protected] librenms]# ./validate.php
LibreNMS | 1.62-70-ge4b49f5
DB Schema | 2020_03_25_165300_add_column_to_ports (162)
PHP | 7.2.8
MySQL | 5.6.30
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.10.5
[FAIL] Database: missing index (sensors_to_state_indexes/state_index_id)
[FAIL] Database: extra index (sensors_to_state_indexes/sensors_to_state_indexes_ibfk_1)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (https://t.libren.ms/discord) or the community site (https://t.libren.ms/5gscd):
SQL Statements:
ALTER TABLE sensors_to_state_indexes
DROP INDEX sensors_to_state_indexes_ibfk_1
ADD INDEX state_index_id
(state_index_id
Files:
/opt/librenms/storage/framework/views/3b20920b4b55193bb9a1c5d22a7caaa7
