Librenms CPU usage is high - need a recommendation
Hi there,
We have a Librenms server (integrated with Oxidized) monitoring 150 devices (switches, FWs, WLC). Oxidized runs once a day.
Our Librenms server processors are: 4 x Intel Xeon Gold 6240 @ 2.60GHz VM.
CPU usage is showing 84.65% in average and 99% in maximum on Librenms dashboard. (Librenms is monitoring it’s server)
Top command is showing CPU is normal except when the server is doing polling (every 5 mins).
Do you think our current CPU usage status is OK for a production environment? Please give me an advice.
If I want to keep the CPU usage around 70% when the server is doing polling, whats CPU/processor will be recommended?
Thank you
check out
