Hello All,
My LibreNMS distributed pollers are working fine. Except one poller - I just installed today (Ubuntu 20.04 + Apache). Devices have been added to this poller, devices keeps up and down (fake alerts, devices were online), and devices are showing “Generic Device”. LibreNMS can not identify devices OS - such as Cisco WLC…
The poller “Total Polling time” are 0 second.
I got no idea on this issue. Can you please give me an advice?
Regards
Jeff Deng
run poller.php -d:
LibreNMS Poller
SQL[select migration
from migrations
order by id
desc limit 1 [] 55.72ms]
SQL[select count(*) as aggregate from migrations
limit 1 [] 55.16ms]
SQL[SELECT version() [] 55.5ms]
Version info:
Commit SHA: xxxxxxxxxxxxxxxxxxxxxxxx
Commit Date: 1604287518
DB Schema: 2020_07_27_00522_alter_devices_snmp_algo_columns (188)
PHP: 7.4.3
MySQL: 10.1.47-MariaDB-0ubuntu0.18.04.1
RRDTool: 1.7.2
SNMP: NET-SNMP 5.8
Updating os_def.cache
Starting polling run:
SQL[SELECT * FROM devices
WHERE disabled
= 0 AND hostname
= ‘labx-akl-wlc01.example.com’ ORDER BY device_id
ASC [] 58.37ms]
SQL[select * from devices
where device_id
= ? limit 1 [12] 55.08ms]
SQL[select * from devices_attribs
where devices_attribs
.device_id
= ? and devices_attribs
.device_id
is not null [12] 56.23ms]
Attempting to initialize OS: generic
OS initialized: LibreNMS\OS\Generic
Hostname: labx-akl-wlc01.example.com
Device ID: 12
OS: generic
Resolved IP: 192.168.11.10
