I am checking our company Librenms setting and want to understand what Librenms is monitoring. I can check the graphs and guess what is it, but i dont about : monitoring interval, snmp oid for that graph, which junos command can check that result …
Do we have any document about that ?
Monitoring interval is 300 seconds by default unless you’ve changed it.
For the snmp OID, you’ll have to dig into the code I’m afraid. Some are listed in the yaml files in includes/definitions/*
thank you so much !
