Component | Version |
LibreNMS | 21.7.0-28-g7c41698e4 |
DB Schema | Not Connected (0) |
PHP | 7.4.16 |
Python | 3.9.5 |
MySQL | ? |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.9 |
[OK] Composer Version: 2.1.5
● mariadb.service - MariaDB 10.5.10 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2021-07-28 12:40:19 AEST; 36min ago
Docs: man:mariadbd(8)
https://mariadb.com/kb/en/library/systemd/
Process: 873 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Process: 923 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 925 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=cd /usr/bin/..; /usr/bin/galera_recovery
; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, statu>
Process: 1228 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 1230 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
Main PID: 1014 (mariadbd)
Status: “Taking your SQL requests now…”
Tasks: 13 (limit: 19079)
Memory: 88.8M
CGroup: /system.slice/mariadb.service
└─1014 /usr/sbin/mariadbd
[28-Jul-2021 12:40:00] NOTICE: ready to handle connections
[28-Jul-2021 12:40:00] NOTICE: systemd monitor interval set to 10000ms
Still can’t find problem.
