Hi everybody,
The librenms.log file grows very fast at 100 kb per sec.
Had to delete it because otherwise there would be no more space left on the server.
When I look in the log file, I see a number of errors. Can someone help me to solve this?
I’ve checked everything and everything seems to be fine. Username, password and server are correct. And the portal (WebUI) simply displays all data correctly.
- The output of
./validate.php
LibreNMS | 21.10.2
DB Schema | 2021_10_03_164200_update_hrsystem_table (221)
PHP | 7.4.14
Python | 3.6.8
MySQL | 10.5.9-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 2.1.9
Modified Files:
includes/definitions/bintec-smart.yaml
The errors I get in librenms.log:
[2021-10-24 10:39:52] production.ERROR: PDOException: SQLSTATE[HY000] [2002] Permission denied in /opt/librenms/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:40
Next Doctrine\DBAL\Driver\PDO\Exception: SQLSTATE[HY000] [2002] Permission denied in /opt/librenms/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDO/Exception.php:18
Next Illuminate\Database\QueryException: SQLSTATE[HY000] [2002] Permission denied (SQL: select * from config
where (config_name
= rrdtool_version) limit 1) in /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:703
After those 3 errors it starts again with the same errors over and over again.
Hope someone can help.
Tia, ragards,
ILaponder
