FAIL: Poller is not running. No poller has run within the last 60 seconds
sudo -u librenms ./validate.php
| LibreNMS | 24.9.1-83-g6a14a9bd7 (2024-10-30T07:48:25+05:00) |
| DB Schema | 2024_10_12_210114_custom_map_legend_colours (303) |
| PHP | 8.3.12 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.8.1
[FAIL] Poller is not running. No poller has run within the last 60 seconds.
Output of “sudo find / -name poller.php”
In StreamHandler.php line 140:
** The stream or file “/opt/librenms/logs/librenms.log” could not be opened in append mode: Failed to open stream: Permission denied **
** The exception occurred while attempting to log: INFO: device:poll 10.20.1.41 (7) polled in 8.729s**
