Last week, I downloaded Centos OVA v1.45 of LibreNMS and founded two problems with the integration with Oxidized.
First problem, oxidized failed to get the configuration from Procurve SW. Solved downgrading some gems:
sudo gem install oxidized -v 0.21
sudo gem uninstall oxidized -v 0.24
sudo gem install oxidized-web -v 0.9.3
sudo gem uninstall oxidized-web -v 0.11.1
sudo gem install oxidized-script -v 0.5.0
sudo gem uninstall oxidized-script -v 0.5.1
The second one, LibreNMS failed to get de config from Oxidized:
sudo cat /var/log/audit/audit.log | grep 8888
type=AVC msg=audit(1543311569.635:736): avc: denied { name_connect } for pid=1277 comm="php-fpm" dest=8888 scontext=system_u:system_r:httpd_t:s0 tcontext=system_u:object_r:unreserved_port_t:s0 tclass=tcp_socket
Solved:
sudo setsebool -P httpd_can_network_connect 1
