./validate
is presenting database out of date and suggests that I run ./lnms migrate
When I do that, I get:
librenms@no1-plibre-3:~$ ./lnms migrate
Application In Production! *
yes
Migrating: 2021_08_26_093522_config_value_to_medium_text
In Connection.php line 703:
SQLSTATE[HY000]: General error: 1025 Error on rename of ‘./librenms/config’ to ‘./librenms/#sql-backup-70d-18c3’ (errno: 168 “Unknown (generic) error from e
ngine”) (SQL: ALTER TABLE config CHANGE config_value config_value MEDIUMTEXT CHARACTER SET utf8mb4 NOT NULL COLLATEutf8mb4_unicode_ci
)In Exception.php line 18:
ngine”)In PDOStatement.php line 117:
ngine”)
Any idea how to work around it? Validate output:
Component Version LibreNMS 21.11.0 DB Schema 2021_07_28_102443_plugins_add_version_and_settings (215) PHP 7.3.29 Python 3.6.8 MySQL 10.6.3-MariaDB RRDTool 1.7.2 SNMP NET-SNMP 5.7.2 ==================================== [OK] Composer Version: 2.1.3
./lnms migrate
