I believe it doesn’t have directly to do with your issue and error messages.
As example I get the following errors in the log file from some of my devices which i didnt’t get earlier.
SQLSTATE[22003]: Numeric value out of range: 1264 Out of range value for column ‘ifOutBroadcastPkts_rate’ at row 1 (Connection: mysql, SQL: UPDATE ports_statistics set ifInNUcastPkts=0,ifInNUcastPkts_prev=0,ifInNUcastPkts_rate=0,ifInNUcastPkts_delta=0,ifOutNUcastPkts=0,ifOutNUcastPkts_prev=0,ifOutNUcastPkts_rate=0,ifOutNUcastPkts_delta=0,ifInDiscards=0,ifInDiscards_prev=0,ifInDiscards_rate=0,ifInDiscards_delta=0,ifOutDiscards=0,ifOutDiscards_prev=0,ifOutDiscards_rate=0,ifOutDiscards_delta=0,ifInUnknownProtos=0,ifInUnknownProtos_prev=0,ifInUnknownProtos_rate=0,ifInUnknownProtos_delta=0,ifInBroadcastPkts=18446744073709408415,ifInBroadcastPkts_prev=18446744073709551576,ifInBroadcastPkts_rate=0,ifInBroadcastPkts_delta=0,ifOutBroadcastPkts=18446744073709544204,ifOutBroadcastPkts_prev=2,ifOutBroadcastPkts_rate=2.9373796295716E+16,ifOutBroadcastPkts_delta=9223372036854775805,ifInMulticastPkts=212439,ifInMulticastPkts_prev=53,ifInMulticastPkts_rate=676.38853503185,ifInMulticastPkts_delta=212386,ifOutMulticastPkts=7415,ifOutMulticastPkts_prev=1,ifOutMulticastPkts_rate=23.611464968153,ifOutMulticastPkts_delta=7414 WHERE port_id = 9556) (Connection: dbFacile, SQL: UPDATE ports_statistics set ifInNUcastPkts=0,ifInNUcastPkts_prev=0,ifInNUcastPkts_rate=0,ifInNUcastPkts_delta=0,ifOutNUcastPkts=0,ifOutNUcastPkts_prev=0,ifOutNUcastPkts_rate=0,ifOutNUcastPkts_delta=0,ifInDiscards=0,ifInDiscards_prev=0,ifInDiscards_rate=0,ifInDiscards_delta=0,ifOutDiscards=0,ifOutDiscards_prev=0,ifOutDiscards_rate=0,ifOutDiscards_delta=0,ifInUnknownProtos=0,ifInUnknownProtos_prev=0,ifInUnknownProtos_rate=0,ifInUnknownProtos_delta=0,ifInBroadcastPkts=18446744073709408415,ifInBroadcastPkts_prev=18446744073709551576,ifInBroadcastPkts_rate=0,ifInBroadcastPkts_delta=0,ifOutBroadcastPkts=18446744073709544204,ifOutBroadcastPkts_prev=2,ifOutBroadcastPkts_rate=2.9373796295716E+16,ifOutBroadcastPkts_delta=9223372036854775805,ifInMulticastPkts=212439,ifInMulticastPkts_prev=53,ifInMulticastPkts_rate=676.38853503185,ifInMulticastPkts_delta=212386,ifOutMulticastPkts=7415,ifOutMulticastPkts_prev=1,ifOutMulticastPkts_rate=23.611464968153,ifOutMulticastPkts_delta=7414 WHERE port_id = 9556)#0 /opt/librenms/includes/polling/ports.inc.php(935): dbUpdate()
#1 /opt/librenms/LibreNMS/Modules/LegacyModule.php(114): include(‘…’)
#2 /opt/librenms/LibreNMS/Poller.php(176): LibreNMS\Modules\LegacyModule->poll()
#3 /opt/librenms/LibreNMS/Poller.php(103): LibreNMS\Poller->pollModules()
#4 /opt/librenms/app/Console/Commands/DevicePoll.php(44): LibreNMS\Poller->poll()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Console\Commands\DevicePoll->handle()
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod()
#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Console/Command.php(208): Illuminate\Container\Container->call()
#11 /opt/librenms/vendor/symfony/console/Command/Command.php(326): Illuminate\Console\Command->execute()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Console/Command.php(178): Symfony\Component\Console\Command\Command->run()
#13 /opt/librenms/vendor/symfony/console/Application.php(1081): Illuminate\Console\Command->run()
#14 /opt/librenms/vendor/symfony/console/Application.php(320): Symfony\Component\Console\Application->doRunCommand()
#15 /opt/librenms/vendor/symfony/console/Application.php(174): Symfony\Component\Console\Application->doRun()
#16 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(201): Symfony\Component\Console\Application->run()
#17 /opt/librenms/app/Console/Kernel.php(66): Illuminate\Foundation\Console\Kernel->handle()
#18 /opt/librenms/lnms(40): App\Console\Kernel->handle()
#19 {main}
my version:
librenms@ubuntu-librenms:~$ ./validate.php
| LibreNMS | 23.11.0 (2023-11-17T03:57:41+01:00) |
| DB Schema | 2023_11_04_125846_packages_increase_name_column_length (273) |
| PHP | 8.1.25 |
| Python | 3.8.10 |
| Database | MariaDB 10.6.16-MariaDB-1:10.6.16+maria~ubu2004 |
| RRDTool | 1.7.2 |
| SNMP | 5.8 |
[OK] Composer Version: 2.6.5
[OK] MySQl and PHP time match
