Lost traffic history on Ethernet interface
Please help me, I lost interface history data on some of my devices, even though the devices were never re-added or removed and I didn’t find any logs in librenms, I only found the voting increase history in the same month as in the picture below:
LibreNMS 24.11.0 (2024-11-20T21:58:54+07:00)
DB Schema 2024_11_07_110342_custommap_edge_add_text_align (307)
PHP 8.2.0
Python 3.9.2
Database MariaDB 10.5.15-MariaDB-0+deb11u1
SNMP 5.9
[OK] Composer Version: 2.8.3
Overall traffic Interfaces:
Polling:
Thank you
Most likely the ifIndex values changed meaning the ports got removed and re-added. Look at eventlog for the device to see if it shows ports being removed and re-added.
Some devices don’t honour static ifIndex values so you need to change the port association mode in Device → Settings → SNMP
Thank you for your answer, I will take the time to read the log and find out more. I will come back later.
I’ve checked but there are no logs showing the port being recreated or anything like that.
