Greatings,
I have devices monitored with the Librenms since a while.
Having some issue with the fdb_count graph missing data, though when I run a discovery to the device I can see the count line out there.
any help will be appreciated.
Basically I am a new user, thanks for the patience.
Awesome tool btw
-bash-4.2$ ./validate.php
Component | Version |
LibreNMS | 21.5.1-41-g0f429e3 |
DB Schema | 2021_25_01_0127_create_isis_adjacencies_table (210) |
PHP | 7.3.28 |
Python | 3.6.8 |
MySQL | 10.5.10-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 2.1.3
[WARN] Global lnms shortcut not installed. lnms command must be run with full path
sudo ln -s /opt/librenms/lnms /usr/bin/lnms
[WARN] Bash completion not installed. lnms command tab completion unavailable.
sudo cp /opt/librenms/misc/lnms-completion.bash /etc/bash_completion.d/
Modified Files:
config.php.default
