Manage Roles - Modifying devices config not working - error 403
LibreNMS 26.6.1-dev.21+91f1ce05f (2026-05-25T17:32:19+02:00)
DB Schema 2026_05_18_120000_port_security_boolean_enable_columns (388)
PHP 8.2.30
Python 3.11.2
Database MariaDB 10.11.14-MariaDB-0+deb12u2
SNMP 5.9.3
I was created new role for user account. Even if I selected all permissions the edit device page is 403 “this action is unautorhized’
Is there any chance that this case will be resolved soon?
permissions are beta: there is a big update pending that will fix a lot of things. Probably need to wait until that is merge before testing again: Permissions implementations and improvements by murrant · Pull Request #19643 · librenms/librenms · GitHub
Thank you so much for this message. I’m really looking forward to this update
It’s out now, if you’re on the daily release then update, if not it will be available in 26.6.0
Excellent! Thanks! :slight_smile:
