- The output of
./validate.php
./discovery.php -h HOSTNAME -d | curl --data-binary @- https://paste.rs/
./poller.php -h HOSTNAME -r -f -d | curl --data-binary @- https://paste.rs/
If you need to post any text longer than a few lines, please use a “pastebin” service, we recommend using https://paste.rs/ or https://paste.sh/
./validate.php
| LibreNMS | 26.9.1 (2026-09-22T14:33:27-03:00) |
| DB Schema | 2026_09_16_120000_widen_ent_physical_rev_columns (403) |
| PHP | 8.4.26 |
| Python | 3.13.5 |
| Database | MariaDB 11.8.6-MariaDB-0+deb13u1 from Debian |
| RRDTool | 1.7.2 |
| SNMP | 5.9.4.pre2 |
[OK] Composer Version: 2.10.3
[FAIL] Some dispatcher nodes did not check in recently
Inactive Nodes:
Buri
[OK] Redis is functional
[OK] No errors found with polling frequencies.
Modified Files:
resources/definitions/os_detection/tplink.yaml
[FAIL] We have found some files that are owned by a different user than ‘librenms’, this will stop you updating automatically and / or rrd files being updated causing graphs to fail.
Files:
/opt/librenms/rrd/smokeping/__sortercache/data.lnmsFPing6-1.storable
/opt/librenms/rrd/smokeping/__sortercache/data.lnmsFPing-1.storable
/opt/librenms/rrd/smokeping/__sortercache/data.lnmsFPing6-0.storable
/opt/librenms/rrd/smokeping/_sortercache/data.lnmsFPing-0.storable
/opt/librenms/rrd/smokeping/appliance/…
and 2 more…
Is it possible to customize the user profile in a beta module? I want site users to be able to acknowledge (ACK) alerts as well as discovery and polling devices. When I tried creating a new role and assigning two roles to the user (user and can_ack), it worked; however, shortly thereafter, the users lost that new role and reverted to having only the user role.
