Good day!
I am attempting to install LibreNMS on a CentOS 7.6 VM. I installed CentOS and started following the directions here:
https://docs.librenms.org/Installation/Installation-CentOS-7-Apache/
When I get down to Configure Apache section, I am unable to edit /etc/httpd/conf.d/librenms.conf as the file is missing. Is there a step missing in the instructions?
No missing step, you just need to create it, and the command in the docs ( vi /etc/httpd/conf.d/librenms.conf
) should do that for you if you write quit (:wq). Otherwise you can just do: touch /etc/httpd/conf.d/librenms.conf
then edit it.
The reason is that the default main Apache conf file should try to load all of the sub conf files in the conf.d directory.
Thank you for getting back to me.
When reading the directions, I was expecting the file to already exist.
