I have a large network (1250 devices)
Network map is not working:
Whoops, looks like something went wrong. Check your librenms.log.
Check your log for more details. (librenms.log)
If you need additional help, you can find how to get help at https://docs.librenms.org/Support.
Is there a way to draw map for large networks?
I have dependencies configured for all devices
Is it possible to draw a map with one parent node and all the childs based on dependencies?
