I know there has been some mention of using addhost.php to add multiple hosts. I need to add 100+ Access Points but when I try and use the .php with the below command (like I have seen in posts) it doesn’t work.
Cheers.
[email protected]:~$ ./addhost.php 172.16.2.120 v2c ccgs-public
Could not connect to 172.16.2.120, please check the snmp details and snmp reachability
Yet if I do it via the GUi.
Adding host 172.16.2.120 community ccgs-public port 161 using udp
Device added 172.16.2.120 (74)
