Hi dear team,
I hope anyone from the community can help me out here.
I have MIB based polling activated. I can see the polling in the device_oids table however i am unable to see the graphs. I am following the below documentation link
https://docs.librenms.org/Extensions/MIB-based-polling/
Also in some records of the table does not have mib name (its empty). Does anyone can guide how to actually open the graphs of these MIB’s ?
Mib based polling highly experimental and may not work with every thing.
Thank you.
Yup i read that actually however i am interested to write/modify some parts of it. Just wanted to confirm that i am on the right track and what is a good start to look at.
Thank you.
Cool, share your code and give back to the community. Make a pull request in git hub.
For sure if i can get something working. still struggling to read the current code
Does anyone know what this could be? its MIB based pooling
MIB: registering
SNMP[snmptranslate -M /opt/librenms/mibs -IR -m all enterprises.6527.6.2.1.2.6.1 2>/dev/null]
SNMPv2-SMI::enterprises.65*.2.6.1
SNMP translated: all::enterprises.6527.6.2.1.2.6.1 -> SNMPv2-SMI::enterprises.6527.6.2.1.2.6.1
Array
MIB: Could not load definition for SNMPv2-SMI::enterprises.6527.6.2.1.2.6.1
