Dear All,
I am new to Libre NMS, though I have installed the same successfully on Ubuntu Server 18.04 and its working fine.
Our aim is use MIB Based Polling for which I have globally configured $config[‘poller_modules’][‘mib’] = true; in config.php file.
Now the problem is, I am not able to add MIBs in the application, or you can say I am not getting the right track of adding/using MIBs.
If somebody would help me out in a laymen manner, I will be highly thankfull.
Kindly help.
:/opt/librenms# ./validate.php
Component |
Version |
LibreNMS |
1.56-43-g8e1a27eae |
DB Schema |
2019_10_03_211702_serialize_config (145) |
PHP |
7.2.19-0ubuntu0.18.04.2 |
MySQL |
10.1.41-MariaDB-0ubuntu0.18.04.1 |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.9.0
[WARN] Your install is over 24 hours out of date, last update: Sat, 19 Oct 2019 05:25:30 +0000
Modified Files:
.codeclimate.yml
.editorconfig
.env.dusk.testing
.env.example
.github/ISSUE_TEMPLATE.md
.github/ISSUE_TEMPLATE/New-Device.md
.github/PULL_REQUEST_TEMPLATE.md
.github/ci-reporter.yml
.github/label-actions.yml
.github/lock.yml
.github/no-response.yml
.github/stale.yml
.gitignore
.mention-bot
.scrutinizer.yml
and 10157 more…
Files:
/opt/librenms/mibs/IF-MIB
/opt/librenms/mibs/ORG_mibs
/opt/librenms/mibs/SNMPv2-SMI
/opt/librenms/mibs/SNMPv2-MIB
/opt/librenms/mibs/MAKSAT-MK8h-MIB
/opt/librenms/mibs/IANAifType-MIB
/opt/librenms/mibs/SNMPv2-TC
First of all you need to fix all those fails in your validate. You shouldn’t ignore that.
Dear Kevin,
Thanks a lot for the quick response.
Is my issue is really related with these fixes ?
If not, then could we go ahead with my main concern.
I have seen a lot of post of yours helping people.
Kindly become a mentor for me and let me out of this please.
Component |
Version |
LibreNMS |
DB Schema |
PHP |
MySQL |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.7.3 |
Modified Files:
.codeclimate.yml
.editorconfig
.env.dusk.testing
.env.example
.github/lock.yml
.github/stale.yml
.gitignore
.mention-bot
.scrutinizer.yml
Hi Kevin,
Please help me out, I am NOT able to Add Device MIBs.
How to do that ?
I need to add some code in opt/librenms/app/Http/Controllers/DeviceGroupController.php to get the count of Up and Down devices coming under all the groups.
Could somebody help.
