[root@libernms librenms]# ./validate.php
| LibreNMS | 1.43-70-g9aa429c |
| DB Schema | 267 |
| PHP | 7.0.31 |
| MySQL | 5.5.56-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.7.2
[WARN] Missing optional PHP extension: posix
[FIX] It is suggested you install php-process or the one that matches your php version
[root@libernms librenms]# yum install php-process
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
- base: mirrors.ges.net.pk
- epel: mirror.dmmlabs.jp
- extras: mirrors.ges.net.pk
- updates: mirrors.ges.net.pk
- webtatic: sp.repo.webtatic.com
Resolving Dependencies
–> Running transaction check
—> Package php-process.x86_64 0:5.4.16-45.el7 will be installed
–> Processing Dependency: php-common(x86-64) = 5.4.16-45.el7 for package: php-process-5.4.16-45.el7.x86_64
—> Package php-common.x86_64 0:5.4.16-45.el7 will be installed
–> Processing Conflict: php70w-common-7.0.31-1.w7.x86_64 conflicts php-common < 7.0
–> Finished Dependency Resolution
Error: php70w-common conflicts with php-common-5.4.16-45.el7.x86_64
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
