Monitor DNS Record
HI All,
Have a public DNS CNAME record pointing to AWS. Is there a way I can check that url is working?
It’s been a while I’ve done something similar but usually to check URLs or SSL certs i would use nagios plugins. It worked out well until i started doing all external monitoring via grafana cloud.
Look into nagios plugins, worked well for me at the time.
