When adding a port that has no previous data collected (standby port in a HA firewall setup) to a multiport graph widget, the graph is not drawn at all and the RRDtool outputs a message “ERROR: absolute path names not allowed when talking to a remote daemon”.
Generating graphs seems to be working fine when all ports have some traffic. Single port graphs work even without any data, they just draw nothing.
Validate:
Component | Version |
LibreNMS | 1.69-69-g0a7586b9f |
DB Schema | 2020_10_12_095504_mempools_add_oids (191) |
PHP | 7.4.3 |
Python | 3.8.5 |
MySQL | 10.3.25-MariaDB-0ubuntu0.20.04.1 |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.8 |
OpenSSL |
[OK] Composer Version: 2.0.8
[INFO] Detected Python Wrapper
[WARN] Global lnms shortcut not installed. lnms command must be run with full path
sudo ln -s /opt/librenms/lnms /usr/local/bin/lnms
[WARN] Bash completion not installed. lnms command tab completion unavailable.
sudo cp /opt/librenms/misc/lnms-completion.bash /etc/bash_completion.d/
[WARN] Your install is over 24 hours out of date, last update: Tue, 01 Dec 2020 07:45:53 +0000
