I’m trying to setup some new alerting. I have a device that gets me the following info for wireless_sensors:
sensor_id: 12605
sensor_deleted: 0
sensor_class: power
device_id: 3435
sensor_index: 268451970
sensor_type: ceraos-rx
sensor_descr: Radio: Slot 2, Port 2 RX Level
sensor_divisor: 1
sensor_multiplier: 1
sensor_aggregator: sum
sensor_current: -48
sensor_prev: -49
What I’m looking to do is setup an alert so if I see say a 10% drop between sensor_current and sensor_prev that I get an alert.
What is the best way to attack this?
For (say) a >10% drop I use variations on:
wireless_sensors.sensor_current < wireless_sensors.sensor_prev * 0.9
HTH
I’m trying a few things, here’s the query I’m doing:
wireless_sensors.sensor_class = “power” AND wireless_sensors.sensor_current < “wireless_sensors.sensor_prev * 1.1”
The * 1.1 is to account for RSSI values being negative. When I put that in and apply it to a couple of radios I get an alert even though the values are not changing and when I hover over the graph, I get graphs named sensor*power and they have no data, it shows the value underneath that not in a graph properly but I must have something goofed up. Any other suggestions?
Not sure - the wireless point-to-point kit I have under monitoring has separate sensor classes for transmit power and RSSI:
wireless_sensors.sensor_class = “rssi”
For this kit power is a +ve dBm vs -ve dBm for RSSI.
What can you see under https://yourserver/wireless/metric=power and https://yourserver/wireless/metric=rssi?
