Hi All,
I am working on a fresh install of Librenms. And I myself am very new to Librenms. I added the devices and added alerts from macros. These are working okay. I need to know how to add OR or | | operator in the alert rules .
Sayyed
Hi All,
Sayyed
The only way to use OR or || is using a macro. Post the rule you are trying to make maybe we can help ya out.
Hi Kevin, Thanks for quick reply .
here is the rule on previous server. I want to have it on the new server.
%ports.port_descr_descr ~ “ISP ASxxx” || %ports.port_descr_descr ~ “Description” || %ports.port_descr_descr ~ “ISP ASXXX” && %macros.port_in_usage_perc > “70”
I dont’ know how to bring in the || operator.
Just create that as a macro and then use the macro in the rule itself.
Have a look at the docs and give it a try.
Where exactly I can go to create a macro. I know its a silly questions . But I should be honest. I know some basics of linux. but not sure about Librenms.
I have seen some posts where people were talking about config.php file. There are few config.ph files in librenms arleady. I dont know which one to edit.
you make your macro in config.php
its usally located in opt/librenms
From the docs.
https://docs.librenms.org/#Alerting/Macros/
Hi Kevin,
I have made the change . as below.
$config[‘alert’][‘macros’][‘rule’][‘EBOX_BGP’] = ‘%bgpPeers.bgpPeerFsmEstablishedTime < “300” && %bgpPeers.bgpPeerState = “established” &&(%bgpPeers.bgpPeerRemoteAs = 1299 && || %bgpPeers.bgpPeerRemoteAs = 174 &&)’;
Is it going to work in background , OR still need to make some rule to get it working. Aslo , if it’s going to show up in alert rule configuration ; where can I see it ???
Hi Kevin,
I can see the rule in Global settings. Now only one question , is it going to work from here itself or I need to enable it or call it somewhere ???
You need to create the rule now and specify that macro.EBOX_BGP as the entity, equals 1
If you would like to use OR in alert rules still. We have a new UI for you to test: https://github.com/librenms/librenms/pull/8293
