Need help with graphs in emails
LibreNMS 23.4.1-50-g927446db7 (2023-05-02T15:02:50-04:00)
DB Schema 2023_04_12_174529_modify_ports_table (250)
PHP 8.2.5
Python 3.8.10
Database MariaDB 10.3.38-MariaDB-0ubuntu0.20.04.1
SNMP 5.8
[OK] Composer Version: 2.5.5
[FAIL] We have detected that your database schema may be wrong
Database: incorrect column (syslog/facility)
Database: incorrect column (syslog/level)
Database: incorrect column (syslog/program)
Database: extra table (log)
Run the following SQL statements to fix it
SQL Statements:
ALTER TABLE syslog CHANGE facility facility varchar(10) NULL ;
ALTER TABLE syslog CHANGE level level varchar(10) NULL ;
ALTER TABLE syslog CHANGE program program varchar(32) NULL ;
DROP TABLE log;
Attempt to fix this issue (y or n)?:n
[OK] MySQl and PHP time match
I have two alerts that sends emails with graphs. One for memory utilization and another for CPU usage. Both were working prior to 9/1/2022. Since then when alerts are generated for CPU usage I get emails stating no processors. Memory utilization alerts still work and the emails contain the graphs. Nothing was changed from the templates that are used. I’m at a loss here as everything was working fine.
