Hello Team!,
I absolutely love LibreNMS and have recently spun up a server in my enterprise environment. I’m having trouble getting the last step of the NFsen to happen. “You should see a new tab for the device called Nfsen.”
I have already completed the steps for configuring NFDump and NFSen per online documentation.
Below is what I have added:
./opt/librenms/config.php
//NFSen RRD dir.
$config[‘nfsen_enable’] = 1;
$config[‘nfsen_split_char’] = ‘_’;
$config[‘nfsen_rrds’][] = ‘/var/nfsen/profiles-stat/live/’;
$config[‘nfsen_rrds’][] = ‘/var/nfsen/profiles-stat’;
$config[‘nfsen_suffix’] = “_yourdomain_com”;
Below is the Validate PHP
Component | Version |
LibreNMS | 1.43-127-g54de88415 |
DB Schema | 268 |
PHP | 7.2.10-0ubuntu0.18.04.1 |
MySQL | 10.1.34-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.2
[FAIL] You have no timezone set for php.
[FIX] http://php.net/manual/en/datetime.configuration.php#ini.date.timezone
[FAIL] The poller (rkubuntu01) has not completed within the last 5 minutes, check the cron job.
[FAIL] Some devices have not completed their polling run in 5 minutes, this will create gaps in data.
[FIX] Check the cron job to make sure it is running and using discovery-wrapper.py
