Quick questions:
Does the network map support real-time device status? I can a nice map view, but trying to see if there is:
- Built in support where a device turns red in color if it goes down
- If someone here has achieved the same with any Third-party plugins or configurations
3) Also, is the network availability map real-time? or does it need to be refreshed
Output of validate.php:
[email protected]:/opt/librenms# ./validate.php
Component Version LibreNMS 1.38-57-g146fc98 DB Schema 247 PHP 7.0.28-0ubuntu0.16.04.1 MySQL 10.0.34-MariaDB-0ubuntu0.16.04.1 RRDTool 1.5.5 SNMP NET-SNMP 5.7.3 ====================================
[OK] Composer Version: 1.6.4
[FIX] Check your poll log and see: http://docs.librenms.org/Support/Performance/
Devices:
10.153.35.20
10.153.35.102
10.153.35.103
10.153.35.104
10.153.35.109
10.153.35.110
10.153.35.112
10.153.35.119
10.153.35.120
10.153.35.121
10.153.35.125
10.153.35.15
Modified Files:
