Network-map
I use Network-map and edit config.php file then I edit my map with normal visible and when I refresh my browser network map change automatically.
[root@localhost librenms]# ./validate.php
LibreNMS 1.55-46-gdada33a
DB Schema 2019_09_05_153524_create_notifications_attribs_index (141)
PHP 7.2.21
MySQL 5.5.60-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.9.0
[root@localhost librenms]# ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
