I just installed on Ubuntu 19.04. All is well until I tried to login for the first time. So, install.php is giving me a login screen, but none of my credentials work. I ran the validate script, here is the output:
LibreNMS | 1.53-1-g8ad55b55b
DB Schema | 2019_05_30_225937_device_groups_rewrite (135)
PHP | 7.2.19-0ubuntu0.19.04.1
MySQL | 10.3.13-MariaDB-2
RRDTool | 1.7.1
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.8.6
[WARN] You have not added any devices yet.
You can add a device in the webui or with ./addhost.php
[WARN] Your install is over 24 hours out of date, last update: Mon, 01 Jul 2019 13:06:27 +0000
Modified Files:
.codeclimate.yml
.editorconfig
.env.dusk.testing
.env.example
.github/ISSUE_TEMPLATE.md
.github/ISSUE_TEMPLATE/New-Device.md
.github/PULL_REQUEST_TEMPLATE.md
.github/ci-reporter.yml
.github/label-actions.yml
.github/lock.yml
.github/no-response.yml
.github/stale.yml
.gitignore
.mention-bot
.scrutinizer.yml
and 9815 more...
And when I try to run the daily, I get this:
error: Your local changes to the following files would be overwritten by merge:
app/Http/Controllers/Widgets/ComponentStatusController.php
doc/Extensions/Applications.md
doc/General/Changelog.md
includes/common.php
includes/definitions/discovery/fortigate.yaml
includes/definitions/voss.yaml
includes/definitions/xos.yaml
includes/html/functions.inc.php
includes/html/pages/wireless.inc.php
includes/html/table/sensors-common.php
includes/html/table/sensors.inc.php
includes/html/table/wireless-sensors.inc.php
Please commit your changes or stash them before you merge.
Aborting
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
