Newbie Help Please?
Hi All,
Very new to LibreNMS so please forgive my questions.
I have added 9 devices (Nokia 7360 ISAM FX) to my install but i am struggling with discovery.
This may be my inexperience but I do not see anything relating to the ISAM discovery (I’ve noticed that under devices, the vendor icon is listed as generic. - not sure if this is related)
I have tried running ./discovery.php from the cli with -d flag to see if there was anything in the output relating to the ISAM ports but I could not see anything promising.
Any help would be very much appricated.
Regards
Mark
Pleased Paste the Output of ./validate.php.
Or Ally, the ISAM should Show Up wirt a Nokia Logo eben discovered.
Hi.
Thanks for the reply. Below is the output from ./validate.php
[root@librenms]# ./validate.php
LibreNMS 1.63-100-gcbb0b52
DB Schema 2020_04_19_010532_eventlog_sensor_reference_cleanup (164)
PHP 7.4.6
Python 3.6.8
MySQL 10.4.12-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.10.6
[root@librenms]#
Interestingly if I run validate from the browers, I get a python warning.
Configuration Ok
Database Ok
Dependencies Ok
Disk Ok
Distributedpoller Ok
Mail Ok
Php Ok
Programs Ok
Python Warning
Warning: Could not check Python dependencies because this script is not running as librenms
Rrd Ok
Rrdcheck Ok
Updates Ok
User Ok
OK… I think I have it. For these devices, there are two SNMP community strings. When using one of them, I get information relating to the chassis and not the individual cards - i suppose the back-haul links. If it use the other community string, LibreNMS identifies the device as Nokia and that its an ISAM.
Happy days…
Just checking some stuff since i have same hardware…are you sure about different communities or do you mean different context of snmp on these devices?
