On Ubuntu 20.04 I have problems to connect DB:
Component |
Version |
LibreNMS |
21.5.1-20-g70023c0b5 |
DB Schema |
Not Connected (0) |
PHP |
7.4.3 |
Python |
3.8.5 |
MySQL |
RRDTool |
1.7.2 |
SNMP |
NET-SNMP 5.8 |
[OK] Composer Version: 2.1.0
And nothing on the logfile abour that !?
Thanks for your help.
Sam.
Maybe related to your other issue.
What’s in librenms.log?
Yes I corrected permissions on some directories and then the database could be built and now I got there:
Sam.
Does your .env
file contain correct settings to connect to your database?
Also run php artisan config:clear
after changing .env
Hello Sam, i am facing the same issue right jow. Could you help me exactly what permissions you have altered to get it working?
What is your output of ./validate.php?
Component |
Version |
LibreNMS |
DB Schema |
Not Connected (0) |
PHP |
7.4.3 |
Python |
3.8.5 |
MySQL |
RRDTool |
1.7.2 |
SNMP |
NET-SNMP 5.8 |
[OK] Composer Version: 2.1.2
Check your database settings in /opt/librenms/.env
system
Closed
9
