Hi - I am also facing the exact same issue on our install - the version is:
LibreNMS | 1.31.01
We have noticed that this worked on an older version of Chrome but the machines are now running the following version: Version 60.0.3112.113 (Official Build) (64-bit) and we cannot rollback (due to corporate lockdowns)
When refreshing that page with the console the only output I get is:
[Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check https://xhr.spec.whatwg.org/
Apologies for jumping on this thread - I can create a new one if that is preferable
(Data has been replaced due to security procedures here)
And from config:
$config[‘auth_ad_require_groupmembership’] = true;
$config[‘auth_ad_groups’][‘Required-Group-1’][‘level’] = 10;
$config[‘auth_ad_groups’][‘Required-Group-2’][‘level’] = 5;
As this has occurred for myself and anderssonpof since upgrading (and we appear to have the same setup) has anything changed in LDAP/AD auth with the latest daily? (1.31.01)
