I am new to LibreNMS and I am trying to get the DDM optical monitoring working on a Nokia 7250 and various other devices. Below are the OID but everything I try to do to add this functionality fails.
I have added this on my development machine and not all values will translate to the same values as the CLI command show port x/x/x. This is due to my lack of understanding of the SFF Committee Standard’s document and how Nokia stores the DDMExteCalRxPowerX to report the correct values.
It all depends on what SFP vendors that you use.
I will submit a patch in a few days to do basic reporting and set the high/low alarm values.
The librenms error is as follows, how should I solve it better
[[email protected] scripts]# ./github-apply 12062
:906: trailing whitespace.
If test data already exists, but is for a different device/configuration with the same OS.
:908: trailing whitespace.
specify a different variant of the OS,
:909: trailing whitespace.
this will be tested completely separate from other variants.
:1160: trailing whitespace.
.1.3.6.1.4.1.50536.3
:6443: space before tab in indent.
INTEGER,
warning: squelched 17 whitespace errors
warning: 22 lines add whitespace errors.
