i’m new to all this but did manage to get librenms (ubuntu 18.04/Apache) installed but when i go to my web browser to finish the installation in the webui , nothing is found at “http://librenms.example.com”. it queries a google search, i can however access it through the ip address of the server, but i read muiltiple threads that it is not the same and should not be done this way. i followed the installation instructions line for line, can anyone provide any help?
Hello spunky424
This is not a valid URL its example You need to browse to your server on your network…Like “http://hostname” or http://ipaddress
so accessing the webgui via the ipaddress of the server is fine? for some reason i read in multiple threads that doing it that way was not the correct way to access librenms.
so logging into the IP of the server that librenms is installed on i see this. the graphics dont seem to be loading properly. how can this be resolved?
This usually happens when you set up your webserver ServerName or base_url incorrectly
i got this resolved by changing the base_url in the config.php. Thanks for the hint/tip! its back up and running again.
