-bash-4.2$ ./validate.php
LibreNMS | 1.65-46-g5a45060
DB Schema | 2020_06_23_00522_alter_availability_perc_column (170)
PHP | 7.3.20
Python | 3.6.8
MySQL | 5.5.65-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
I just installed LibreNMS on CentOS 7. Everything is good with the ./validate.php. I have rsyslog set up and Syslog messages are being populated into the correct log file. I have turned off the firewall and selinux. I have validated DNS with forward and reverse lookups. I have also reboot the VMs.
The issue is that Syslog messages are making into LibreNMS VM but are not being forwarded from rsyslog to LibreNMS. The VM that hosts LibreNMS does have its Syslog messages forwarded but not any other VM. One more symptom I see is that the Event View has not pulled any messages from the VM for the last 2 days. There has not been any network changes in the past few days either.
/opt/librenms/syslog.php is the same as what is on here
“/opt/librenms/config.php”
### Enable Syslog
$config[‘enable_syslog’] = 1;
$config[‘syslog_purge’] = 30;
Any help would be appreciated, thanks.
