Not seeing 'Neighbours' when I click on a switch
I added a cisco 2960 switch and I don’t see the ‘Neighbours’ option between Routing and STP. The switch has LLDP and CDP enabled (but no active connections to another switch, at this time).
Hi @dt-lib
If you have no neighbours, then the option is not visible. Add one neighbour and do a new discovery, and this option will appear, except if the discovery module “discovery-protocols” is disabled. (which you can check in Edit->Modules on the device)
PipoCanaja
Thank you for that information, I will check it out.
