Ooops something went wrong on GUI
Hi, Guys.
Can anyone please shed some light on this issue?
I’m seeing the following error when trying to browse to libre:
I’ve run ./validate.php which shows the following error:
LibreNMS 24.5.0-7-gdf6a42f2a (2024-05-22T17:18:42+00:00)
DB Schema Not Connected (0)
PHP 8.1.2-1ubuntu2.17
Python 3.10.12
Database Not Connected
SNMP 5.9.1
[OK] Composer Version: 2.7.6
Seems the database is disconnected but how do i reconnect it?
Libre logs show the following:
Next Illuminate\Database\QueryException: SQLSTATE[HY000] [1040] Too many connections (Connection: mysql, SQL: select * from config where (config_name = rrdtool) limit 1) in /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:829
Stack trace:
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(783): Illuminate\Database\Connection->runQueryCallback()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(431): Illuminate\Database\Connection->run()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2798): Illuminate\Database\Connection->select()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2786): Illuminate\Database\Query\Builder->runSelect()
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3340): Illuminate\Database\Query\Builder->Illuminate\Database\Query{closure}()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2787): Illuminate\Database\Query\Builder->onceWithColumns()
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(738): Illuminate\Database\Query\Builder->get()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(722): Illuminate\Database\Eloquent\Builder->getModels()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Concerns/BuildsQueries.php(333): Illuminate\Database\Eloquent\Builder->get()
#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(567): Illuminate\Database\Eloquent\Builder->first()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(599): Illuminate\Database\Eloquent\Builder->firstOrCreate()
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Traits/ForwardsCalls.php(23): Illuminate\Database\Eloquent\Builder->updateOrCreate()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2334): Illuminate\Database\Eloquent\Model->forwardCallTo()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2346): Illuminate\Database\Eloquent\Model->__call()
#14 /opt/librenms/LibreNMS/Config.php(262): Illuminate\Database\Eloquent\Model::__callStatic()
#15 /opt/librenms/LibreNMS/Config.php(466): LibreNMS\Config::persist()
#16 /opt/librenms/LibreNMS/Config.php(61): LibreNMS\Config::processConfig()
#17 /opt/librenms/app/Providers/ConfigServiceProvider.php(27): LibreNMS\Config::load()
#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Providers\ConfigServiceProvider->boot()
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod()
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1030): Illuminate\Container\Container->call()
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1011): Illuminate\Foundation\Application->bootProvider()
#25 [internal function]: Illuminate\Foundation\Application->Illuminate\Foundation{closure}()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1012): array_walk()
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\Application->boot()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(263): Illuminate\Foundation\Bootstrap\BootProviders->bootstrap()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(447): Illuminate\Foundation\Application->bootstrapWith()
#30 /opt/librenms/LibreNMS/Util/Laravel.php(44): Illuminate\Foundation\Console\Kernel->bootstrap()
#31 /opt/librenms/includes/init.php(90): LibreNMS\Util\Laravel::bootCli()
#32 /opt/librenms/syslog.php(12): require(‘…’)
#33 {main}
PDOException: SQLSTATE[HY000] [1040] Too many connections in /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php:65
Stack trace:
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(65): PDO->__construct()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(45): Illuminate\Database\Connectors\Connector->createPdoConnection()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connectors/MySqlConnector.php(24): Illuminate\Database\Connectors\Connector->createConnection()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connectors/ConnectionFactory.php(184): Illuminate\Database\Connectors\MySqlConnector->connect()
#4 [internal function]: Illuminate\Database\Connectors\ConnectionFactory->Illuminate\Database\Connectors{closure}()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(1339): call_user_func()
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(1375): Illuminate\Database\Connection->getPdo()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(528): Illuminate\Database\Connection->getReadPdo()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(423): Illuminate\Database\Connection->getPdoForSelect()
#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(816): Illuminate\Database\Connection->Illuminate\Database{closure}()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(783): Illuminate\Database\Connection->runQueryCallback()
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(431): Illuminate\Database\Connection->run()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2798): Illuminate\Database\Connection->select()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2786): Illuminate\Database\Query\Builder->runSelect()
#14 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3340): Illuminate\Database\Query\Builder->Illuminate\Database\Query{closure}()
#15 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2787): Illuminate\Database\Query\Builder->onceWithColumns()
#16 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(738): Illuminate\Database\Query\Builder->get()
#17 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(722): Illuminate\Database\Eloquent\Builder->getModels()
#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Concerns/BuildsQueries.php(333): Illuminate\Database\Eloquent\Builder->get()
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(567): Illuminate\Database\Eloquent\Builder->first()
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(599): Illuminate\Database\Eloquent\Builder->firstOrCreate()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Traits/ForwardsCalls.php(23): Illuminate\Database\Eloquent\Builder->updateOrCreate()
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2334): Illuminate\Database\Eloquent\Model->forwardCallTo()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2346): Illuminate\Database\Eloquent\Model->__call()
#24 /opt/librenms/LibreNMS/Config.php(262): Illuminate\Database\Eloquent\Model::__callStatic()
#25 /opt/librenms/LibreNMS/Config.php(466): LibreNMS\Config::persist()
#26 /opt/librenms/LibreNMS/Config.php(61): LibreNMS\Config::processConfig()
#27 /opt/librenms/app/Providers/ConfigServiceProvider.php(27): LibreNMS\Config::load()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Providers\ConfigServiceProvider->boot()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod()
#32 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call()
#33 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1030): Illuminate\Container\Container->call()
#34 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1011): Illuminate\Foundation\Application->bootProvider()
#35 [internal function]: Illuminate\Foundation\Application->Illuminate\Foundation{closure}()
#36 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1012): array_walk()
#37 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\Application->boot()
#38 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(263): Illuminate\Foundation\Bootstrap\BootProviders->bootstrap()
#39 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(447): Illuminate\Foundation\Application->bootstrapWith()
#40 /opt/librenms/LibreNMS/Util/Laravel.php(44): Illuminate\Foundation\Console\Kernel->bootstrap()
#41 /opt/librenms/includes/init.php(90): LibreNMS\Util\Laravel::bootCli()
#42 /opt/librenms/syslog.php(12): require(‘…’)
#43 {main}
Next Illuminate\Database\QueryException: SQLSTATE[HY000] [1040] Too many connections (Connection: mysql, SQL: select * from config where (config_name = traceroute) limit 1) in /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:829
Stack trace:
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\App^C
Thanks in advanced,
James
Further investigation in ./daily.sh shows the following:
librenms@localhost:~$ ./daily.sh
Updating SQL-Schema FAIL
In Connection.php line 829:
SQLSTATE[HY000] [1698] Access denied for user ‘librenms’@‘localhost’ (Connection: mysql, SQL: update cache_locks set owner = gkwdHsExW7uqpFlm, expiration = 1
716547067 where key = laravel_cache_framework/command-migrate and (owner = gkwdHsExW7uqpFlm or expiration <= 1716543467))
In Connector.php line 65:
Cleaning up DB OK
Possibly a permission issue, how do i fix this? Sorry quite new to linux / ubuntu.
Thanks in advanced,
James
Ok seems I have resolved this by changing the DB_USERNAME in .env file.
The only thing i did was change it to something else and change it back to original which sorted it.
No idea how or why but its working now.
Thanks,
James
You temporarily exceeded your max connection setting for your mysql server. I suggest you increase that. Any other changes you made had no affect.
Hi, Murrant.
How do i increase max connections?
Thank you,
James Stoner
https://www.google.com/search?q=mysqld+increase+max+connections
Hi, Murrant
Thanks. I will give this a go.
Appreciate the support from all.
Thank you,
James
