We have a dashboard that was created by a user that has since been deleted. Nobody else has access to the dashboard, and we need to know how this can be deleted?
I guess you could delete the row from your librenms database.
login to your mysql server.
use name-of-database;
Find the dashboard_id number for the row in:
select * from dashboards;
Delete the row with that number:
DELETE FROM dashboards WHERE dashboard_id = number;
Or change the value of access to 2 (shared read/write) for the row and try to delete it from the website.
Update dashboards set access = ‘2’ where dashboard_id = number;
