So, it not working:) If I call ./discovery.php -d -h -m ‘os’ I see
| MES2324P AC 28-port 1G/10G Managed Switch with 24 POE+ ports | .1.3.6.1.4.1.35265.1.92 |
SNMP['/usr/bin/snmpget' '-v3' '-l' 'authPriv' '-n' "" '-a' 'SHA' '-A' 'PASSWORD' '-u' 'USER' '-x' 'DES' '-X' 'PASSWORD' '-Oqv' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/eltex:/opt/librenms/mibs/arris' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.1166.1.621.14.2.0']
No Such Object available on this agent at this OID
SNMP['/usr/bin/snmpget' '-v3' '-l' 'authPriv' '-n' "" '-a' 'SHA' '-A' 'PASSWORD' '-u' 'USER' '-x' 'DES' '-X' 'PASSWORD' '-Oqv' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/eltex' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.8072.1.3.2.3.1.2.6.100.105.115.116.114.111']
Attempting to initialize OS: eltex-mes2324p
OS initialized as Generic
OS: (eltex-mes2324p)
Yes, I removed line “text: ‘Eltex’” from includes/definitions/eltex-mes2324p.yaml and added sysDescr while tried solve the problem.
Also, added dot in oil, still not working even after rm -f cache/os_defs.cache
Can you give me some advice? Maybe it should be solved only with .php?
