[OK] Composer Version: 2.1.6
Modified Files:
rrd/.gitignore
TRUNCATE TABLE ospf_areas; and ospf_instances, ospf_nbrs,ospf_ports would be one way it. you could also more specifically remove the ones that are duplicated by looking through the tables and finding their IDs.
