I have a problem that some newly created devices dont generate a overall graph.
All graphs on the devices work except the overall.
What I found if that the CDEF:inB= CDEF:outB= don’t include any rrd-files.
How do I troubleshoot this? All I find on when searching is that if the file is missing it is not sent to the rrdtool command. How do I know what file should be there if it is missing?
Most of my devices overall work, I have found this error on some Cisco ASA firewealls that we added this week.
I run this in docker with jarischaefer/docker-librenms:1.68 and a local MariaDB.
| LibreNMS | 1.68 |
| DB Schema | 2020_09_22_172321_add_alert_log_index (174) |
| PHP | 7.4.10 |
| Python | 3.6.9 |
| MySQL | 5.5.65-MariaDB |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.13
[WARN] Your install is over 24 hours out of date, last update: Wed, 30 Sep 2020 03:16:05 +0000
You can switch back to master with git checkout master
Modified Files:
composer.json
