Hi Guys,
After I run Oxidized it pulls all required devices and then starts with this.
and if I stop this with CTRL + C, it removes all of the discovered hosts.
Hi Guys,
This Issue was resolved by running
oxidized --daemonize
as it forks the process
Can Anyone help me with this as it seems not to be pulling the config data
This is a MikroTik
This should be MikroTik
You probably want to look at model_map in your oxidized config
e.g
model_map:
cisco: ios
mikrotik: routeros
Check this thread on how to debug if LibreNMS returns a different value https://github.com/ytti/oxidized/issues/1033
config
router.db
