Oxidized within Librenms
Guys,
With Oxidized 0.22 ssh access fails to all Arista devices:
W, [2018-06-11T12:36:33.201478 #13355] WARN – : 10.102.125.63 raised Net::SSH::AuthenticationFailed with msg “Authentication failed for user [email protected]
D, [2018-06-11T12:36:33.201612 #13355] DEBUG – : lib/oxidized/node.rb: Oxidized::SSH failed for dl1040102.pan.local
on the same box, if you ssh [email protected] . it works?
Yep, it works
Guys, I fixed it, there was an issue with ssh.rb file, whoever writes the code, need to add keyboard-interactive
in the auth methods, and it will fix the issue
