I would like graph the connection rate for our PA3020 firewalls.
show session info
<snip>
New connection establish rate: 32 cps
</snip>
I have MIBS available.
Suggestions how to go about this are very welcome.
show session info
<snip>
</snip>
Hi @SandMouse
It depends on the type of SNMP data of this OID.
Then you can add it directly to the YAML file describing the sensors of PaloAlto devices :
includes/definitions/discovery/panos.yaml
You could add, just at the line below sensors:
count:
data:
oid: yourTextualOID
num_oid: '.yourNumericalOID.{{ $index }}'
descr: 'YourDecription'
If it is a Counter SNMP value, then there is no way other than PHP code to add the sensor.
Some docs to help :
https://docs.librenms.org/Developing/os/Health-Information/
https://docs.librenms.org/Developing/Sensor-State-Support/
Thank you.
