Hello
I have just setup LibreNMS want to know how to associate a port to be a peering, transit or customer port
regards
Hello
regards
Hi @mankomal
The instructions on how to do this are here: http://docs.librenms.org/Extensions/Port-Description-Parser/#configuring-interface-descriptions-for-parsing
thanks
tslytsly
Ok! I had read that manual several times but didn’t actually understood so now I finally have gotten the way to do it in case someone stumbles here and is looking this for MikroTik then in comments of the interface just mention parsing text with : and it will work
@tslytsly
Exactly!
So, for your 100Mbps peering connection to ISP A on a Mikrotik you would enter the following text:
Peering: ISP A [100Mbps]
