The group write permission on /opt/librenms/bootstrap/cache/packages.php is being removed after running daily.sh.
[email protected]:/opt/librenms# ./validate.php
LibreNMS | 1.48.1-84-g8929cdb45
DB Schema | 2019_02_10_220000_add_dates_to_fdb (132)
PHP | 7.2.15-0ubuntu0.18.04.1
MySQL | 10.1.38-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.8.4
Files:
After running the recommended permission fixes, validate.php shows no failures. Here are the permissions on packages.php:
[email protected]:/opt/librenms# ls -l /opt/librenms/bootstrap/cache/
total 16
-rwxrwxr-x 1 librenms librenms 1059 Feb 25 10:00 packages.php
-rw-rw-r-- 1 librenms librenms 11646 Feb 25 10:00 services.php
After running daily.sh, the group write permission is removed. This causes validate.php to again fail due to permissions on packages.php. Here are the permissions after running daily.sh:
total 16
-rwxr-xr-x 1 librenms librenms 1059 Feb 25 10:18 packages.php
-rw-rw-r-- 1 librenms librenms 11646 Feb 25 10:18 services.php
