Php/php-fpm and high CPU usage after nightly update
LibreNMS  | 22.8.0
DB Schema | 2022_07_03_1947_add_app_data (244)
PHP       | 8.1.9
Python    | 3.8.10
Database  | MariaDB 10.3.34-MariaDB-0ubuntu0.20.04.1
SNMP      | 5.8
[OK]    Composer Version: 2.4.1
[OK]
[OK]    MySQl and PHP time match
[OK]    Redis is unavailable
Posting librenms.log per request - title of post covers issue. See here for Discord discussion.
Log file: https://paste.c-net.org/GuiseForbid (let me know if this doesn’t work - should be a gzip file)
murrant requested I exclude SQL errors from the log, so I used the following regex to generate the gzip log: grep -Ev '(^\#[0-9]+\ |Stack trace|Too many connections|^[[:space:]]*$)' librenms.log.1
Let me know if I need to attach any additional information.
Does https://github.com/librenms/librenms/pull/14291 help?
What does ./scripts/composer_wrapper.php show facade/flare-client-php show?
Got someone to do some troubleshooting. It should be fixed after update.
Still curious as to why CPU usage was so high. I’ve had this enabled in production for a couple of weeks now.
i have same issue from midnight …from 5 to 5 minute 100 cpu usage.
bash-4.4$ ./scripts/composer_wrapper.php show facade/flare-client-php
descrip. : Send PHP errors to Flare
keywords : exception, facade, flare, reporting
versions : * 1.10.0
type : library
license : MIT License (MIT) (OSI approved) MIT License | Software Package Data Exchange (SPDX)
homepage :
source :213fa2c69e120bca4c51ba3e82ed1834ef3f41b8
dist : [zip] https://api.github.com/repos/facade/flare-client-php/zipball/213fa2c69e120bca4c51ba3e82ed1834ef3f41b8 213fa2c69e120bca4c51ba3e82ed1834ef3f41b8
path : /opt/librenms/vendor/facade/flare-client-php
names : facade/flare-client-php
support
autoload
files
psr-4
Facade\FlareClient\ => src
requires
facade/ignition-contracts ~1.0
illuminate/pipeline ^5.5|^6.0|^7.0|^8.0
php ^7.1|^8.0
symfony/http-foundation ^3.3|^4.1|^5.0
symfony/mime ^3.4|^4.0|^5.1
symfony/var-dumper ^3.4|^4.0|^5.0
requires (dev)
friendsofphp/php-cs-fixer ^2.14
phpunit/phpunit ^7.5
spatie/phpunit-snapshot-assertions ^2.0
It appears that the package is not installed.
Things have been calm since I last posted about this - CPU usage has returned to normal and the logs are not filling with SQL errors any longer. I made no changes other than running daily.sh.
@robdb I wonder if that is why cpu usage was high?
Your guess is as good as mine - do I need to install that package? It was odd that it just started out of nowhere.
./scripts/composer_wrapper.php install --no-dev (which is part of daily.sh) should install that package.
